Hello,
I have a new 10 micron 2000 HPS mount. I don't need to plate solve anymore. Is there an option in Automatic Observation menu to disable plate solving?
Is plate solving still needed for Prism for other tasks besides pointing?
Thank you
Can I disable plate solving in automatic observation?
dan_adrian
Dekelver Pieter-Jan
Re: Can I disable plate solving in automatic observation?
Yes, you can disable platesolving in the Automation setup.
Under "Telescope" you can deselect platesolving.
Platesolving is not needed for prism to take images of an object. It slews to the wanted object, and just start imaging.
dan_adrian
Under Telescope I have:Dekelver Pieter-Jan a écrit : ↑17 janv. 2024, 09:47 Yes, you can disable platesolving in the Automation setup.
Plate solve:
1. Classic plate solve
2. Classic then local ANSVR
3. Classic then .NET
4. ASTAP
I can't deselect all, I have to choose one.
Did you mean another option?
Below is my Telescope config window
The checkbox above the radio group box is deselected, so this should not occur.
dan_adrian
