Page 2 sur 2
Re: Pb avec DMK41 et OrionStarShoot.
Posté : 25 sept. 2011, 23:36
par Armand ROULLEAU
Voici donc le résultat du ProcessExplorer:
Process PID CPU Private Bytes Working Set Description Company Name
prism.exe 1264 1 743 808 K 1 317 552 K PRISM Alcor System
ASCOM.GeminiTelescope.exe 2156 3.13 38 800 K 31 128 K ASCOM GeminiTelescope server ASCOM Initiative
ccsvchst.exe 1968 28 152 K 11 744 K Symantec Service Framework Symantec Corporation
explorer.exe 572 23 152 K 5 588 K Explorateur Windows Microsoft Corporation
svchost.exe 1128 20 912 K 24 284 K Generic Host Process for Win32 Services Microsoft Corporation
VProSvc.exe 2020 17 412 K 1 544 K Service Module Symantec Corporation
procexp.exe 1540 14 756 K 20 272 K Sysinternals Process Explorer Sysinternals - www.sysinternals.com
ccsvchst.exe 1308 13 268 K 7 556 K Symantec Service Framework Symantec Corporation
cdcicon.exe 500 10 568 K 9 456 K
winlogon.exe 732 7 608 K 3 416 K Application d'ouverture de session Windows NT Microsoft Corporation
jqs.exe 1872 7 460 K 1 380 K Java(TM) Quick Starter Service Sun Microsystems, Inc.
svchost.exe 1324 4 944 K 5 384 K Generic Host Process for Win32 Services Microsoft Corporation
lsass.exe 788 3 880 K 1 752 K LSA Shell (Export Version) Microsoft Corporation
spoolsv.exe 1452 3 296 K 3 592 K Spooler SubSystem App Microsoft Corporation
LUCOMS~1.EXE 3912 3 284 K 5 516 K LiveUpdate Engine COM Module Symantec Corporation
svchost.exe 964 3 136 K 3 680 K Generic Host Process for Win32 Services Microsoft Corporation
VProTray.exe 672 3 008 K 5 688 K Tray Application Symantec Corporation
svchost.exe 1876 2 820 K 3 260 K Generic Host Process for Win32 Services Microsoft Corporation
wmiprvse.exe 592 2 800 K 4 892 K WMI Microsoft Corporation
nvsvc32.exe 260 2 612 K 3 220 K NVIDIA Driver Helper Service, Version 175.16 NVIDIA Corporation
rundll32.exe 452 2 400 K 2 664 K Exécuter une DLL en tant qu'application Microsoft Corporation
GoogleUpdaterService.exe 1080 2 268 K 3 772 K gusvc Google
winvnc.exe 1624 1 848 K 3 388 K Serveur VNC pour Win32 www.ultravnc.fr
svchost.exe 1032 1 812 K 2 940 K Generic Host Process for Win32 Services Microsoft Corporation
svchost.exe 2456 1 712 K 2 600 K Generic Host Process for Win32 Services Microsoft Corporation
services.exe 776 1 696 K 3 416 K Applications Services et Contrôleur Microsoft Corporation
taskmgr.exe 288 1 672 K 1 768 K Gestionnaire des tâches de Windows Microsoft Corporation
csrss.exe 708 1 624 K 2 800 K Client Server Runtime Process Microsoft Corporation
svchost.exe 1216 1 352 K 2 800 K Generic Host Process for Win32 Services Microsoft Corporation
svchost.exe 1596 1 204 K 2 576 K Generic Host Process for Win32 Services Microsoft Corporation
alg.exe 3164 1 164 K 2 716 K Application Layer Gateway Service Microsoft Corporation
AluSchedulerSvc.exe 296 1 040 K 644 K Automatic LiveUpdate Scheduler Service Symantec Corporation
CALMAIN.exe 2356 1 004 K 2 004 K Canon Camera Access Library 8 Canon Inc.
ctfmon.exe 1120 852 K 2 208 K CTF Loader Microsoft Corporation
smss.exe 628 168 K 308 K Gestionnaire de session Windows NT Microsoft Corporation
System Idle Process 0 96.88 0 K 16 K
System 4 0 K 132 K
Interrupts n/a < 0.01 0 K 0 K Hardware Interrupts and DPCs
Posté : 07 oct. 2011, 18:26
par Armand ROULLEAU
Pas de réponse sur la gestion de la mémoire??
Posté : 08 oct. 2011, 10:20
par Stéphane Charbonnel
Je débarque sur le sujet. J'ai souvenir d'avoir utilisé une DMK41 en USB sur un portable WIN7. Ca ne posait pas de problème en directshow (uniquement). Cependant, il est maintenant reconnu que les DMK tournent mieux sous WIN7 que sous WIN XP.
Il faut procéder dans l'ordre :
* Chez Imaging Source : aller charger les derniers drivers de la caméra et les installer.
* Avec IC Capture (le soft propriétaire d'IS) : Avez vous essayé les 15 poses par secondes et ceci suffisamment longtemps en regardant si votre CPU est occupée ?
Posté : 26 oct. 2011, 15:00
Je vais donc procéder dans votre style : "Avec IC Capture (le soft propriétaire d'IS) : Avez vous essayé les 15 poses par secondes et ceci suffisamment longtemps en regardant si votre CPU est occupée ?"
Au passage, Cyril ne possède pas tout le matériel du monde entier. N'ayant pas de DMK41 à sa disposition, je ne vois pas comment ce qu'il va vous répondre sera plus pertinent que des avis d'utilisateurs qui eux en ont une.
Posté : 16 nov. 2011, 20:54
par Armand ROULLEAU
Finalement, j'ai toujours le même problème également avec mon Orion starshoot solar system, une occupation en mémoire qui monte entre 1 et 2Go...
