Hi,
What commands are available via TCP/IP in the Command Server? I can't find them in the documentation.
Thank you
What commands are available via TCP/IP Command Server?
dan_adrian
Re: What commands are available via TCP/IP Command Server?
Hello,
This is quite few ... this is why this is not documented.
You can slew a telescope. I can share a source code that talks to this tcp server.
What would you like to have / expect ?
