Good Morning Prism,
I have the following equipment below. I'm working an issue where I'm seeing PRISM report that my focuser is not found and causing a fault alert. However, if i kill the celestron driver and restart everything comes up normally. I see the condition occur in a few scenarios 1) If the system is just connected and not performing any operation 2) During a park sequence 3) A slew and 4) tracking. This morning I enabled the log debugging tool to see if I could reproduce the issue (this occurred 5 times last night during an automated session), you will see in the prism log from time "UTC:2023-09-20-13-08-35 UTC:2023-09-20-13-08-46" during a slew from Polaris to park the error occurred. I also attempted to increase the polling interval on the hardware and focuser its currently set to 4.5 seconds to see if that would resolve the issue. I had a similar issue with our university system and this seems to resolve it, we only see it during some shutdown sequences. I was hoping it was just a bad cable but I replaced the power cable and swapped the aux cable selector (moved from aux 1 to aux 2) with no luck. Let me know if you need additional information.
Update (09/20/23): As a last ditch effort, I opened an unused Pegasus 12-volt connector to see if that would change anything. I left the system in the parked position for about 5 hours and no disconnect occurred and ran an automated session without it disconnecting. Attached is the log and automated session logs.
Equipment Setup:
OTA: Celestron 8-inch
Mount: AVX Mount
Focuser: Celestron Focuser connected to Aux 2
Camera: ZWO-1600 and 1290-mini (Bandwidth set to 5)
Hub: Pegasus Astro (Connects all cams and Hand Controller. Note, I attempted to plug the hand controller into the PC no change in behavior)
Note, we have Pegasus power the mount using the 12v output.
Thanks
Marcel
Telescope Focuser not found
ALPHA_OBS2021
- Fichiers joints
- Obsauto__UTC_2023-09-20__03h28m18s.zip
- (99.32 Kio) Téléchargé 372 fois
- UTC_2023-09-20-13h02m31s_LogFile.zip
- (272.11 Kio) Téléchargé 368 fois
Re: Telescope Focuser not found
Hello,
I can see this in the log file
ConnectTelescopeDevices -> Initialization error of Focuser not found - primary focuser
I do not know this focuser, is it a pure serial focuser ; or serial over USB ?
Please share more detail on this hardware.
Rgds,
Rgds,
ALPHA_OBS2021
Good Afternoon,
This is a Celestron auto Focuser, it is powered by a external 12v input. In my setup Pegasus provides the voltage input. Data connections can come from two sources a USB A to B or the celestron aux cable connection. I think it is a 9-pin connection that goes to the mount it self. In my configuration I it connected to Aux1 but have attempted the run on Aux 2.
Does it work with celestron software ?
Dou you have a PDF doc for this focuser ?
