Dear,
Is it possible that when a script has been run in Prism, at the end, it writes all the "PRINTED lines" to a log file? So i can read the log file afterwards?
Thank you.
Save Script log
- Marc SERRAU
Re: Save Script log
Of course, there is :
SAVE_DISPLAYSCRIPT NomFichierLog$
Marc Serrau
Dekelver Pieter-Jan
Re: Save Script log
Thank you! Will test soon.
PS: If it would be possible to let the prism close by using the script function, this would be also great.
- Marc SERRAU
Re: Save Script log
I do not know how to do that easily. May be with .bat shell script launched with EXECEXTERNAL or EXECPROCESS ?
With the ObsAuto function, I use a .bat file that shutdown the computer. But it is a bad solution because Prism is active and some files may be not well closed. I asked the author of Prism to implement a better solution (see : https://forum.prism-astro.com/viewtopic.php?t=3169 )
Marc Serrau
Dekelver Pieter-Jan
Re: Save Script log
Dear,
I use a bat file to at this moment to KILL prism.
I first disconnect camera and scope and then i run the BAT file script.
