Cher,
Je sais que vous pouvez écrire du texte avec un script. Mais est-il également possible d’écrire à une position prédéfinie ? Ainsi, au lieu de la désignation des pixels, les éléments suivants :
"Centre en Haut" ?
Est-ce possible en langage script ? Merci.
Texte dans l'image: "Centre en Haut" en langage script
Dekelver Pieter-Jan
Re: Texte dans l'image: "Centre en Haut" en langage script
Est il possible de développer cette question, je ne la comprends pas.
Dekelver Pieter-Jan
Dear Cyril,
My apologies for englisch, but it's better for me to explain.
For creating my presentation of the observation i use Prism V11 to wright information on the image.
I know how to wright text using script function. this works by using pixel values as position.
For the comet name i still use the "write text" function in the program itself.
Because the comet name difference from length. And i want to always place the name in the middle of the image at the top.
I don't know if the script has a function to place the the text in the middle of the image at the top. Just like it is an option inside prims
So in conclusion: is there a script option that has the same function as: "Centre en haut"
Thank you.
Thank you.
Sorry no, there's no such script command that is as advanced as this form.don't know if the script has a function to place the the text in the middle of the image at the top. Just like it is an option inside prims
Dekelver Pieter-Jan
Dear,
And is this possible to implent in the script language? I understand that this is not something that you would put on your high urgenty list, but would be much appreciated!
