astropy-wcs FITS error solution
Posté : 01 nov. 2023, 03:13
Prism v.11 creates a FITS header that is not compatible with astropy.wcs (world coord. system).
In order to assure compatibility, I had to delete the following header information
Test:
Output:
Without keyword deletion:
Code : Tout sélectionner
from astropy.io import fits
# open the fits
hdul = fits.open('PRISM01.fits', mode='update')
h = hdul[0].header
# remove keywords
h.remove('XPIXELSZ')
h.remove('YPIXELSZ')
h.remove('CDELTM1')
h.remove('CDELTM2')
# save the header
hdul.flush()
# Close
hdul.close()
from astropy.wcs import WCS
hdulist = fits.open('PRISM01.fits')
wcs = WCS(hdulist[0].header)
wcs
WCS Keywords
Number of WCS axes: 2
CTYPE : 'RA---TAN' 'DEC--TAN'
CRVAL : 338.9776673617 33.94929211956
CRPIX : 2262.5 1812.5
CD1_1 CD1_2 : -8.023616067367e-06 -0.0002569870529751
CD2_1 CD2_2 : -0.0002570335859688 7.94778752437e-06
NAXIS : 4524 3624
ValueError: ERROR 5 in wcsset() at line 2775 of file cextern/wcslib/C/wcs.c:
Invalid parameter value.
ERROR 4 in linset() at line 737 of file cextern/wcslib/C/lin.c:
Failed to initialize distortion functions.
ERROR 3 in dssset() at line 2697 of file cextern/wcslib/C/dis.c:
Coefficient scale for DSS on axis 1 is zero..
